i really need help. camaro is pissing me off
So about two months ago my car was running perfectly fine then it starts to blow smoke, but the temp gauge doesn't show that it is over heating. it was boiling the coolant out of the reservoir tank and the reservoir tank only i have since then checked the relays, fuses, changed the thermostat, replaced the coolant temperature sensor, and now i am out of ideas. MY cars fans are not going on unless the a/c is on. today i finally replaced the coolant temperature sensor and realized that the fans are still not coming on... after 20 in the car and driving it the temperature started to go up (for the First time ever) and then was once again throwing the coolant out through the reservoir tank.
i was told to check the oil to see if it had water or was milky, which could mean a head gasket, but everything seemed fine... i can take anything..... please help im desperate at this point...
Hey guys I actually got the car to work... It was actually that the low speed on the fan wasn't coming on so my car wasn't being cooled... Tool it to the shop and they got me set up with a radiator flush and a new set of working ls1 fans..... Glad it worked after this I followed to only get about 8 mpg ... I really missed the car lol
