TripleWhite96
03-26-2011, 08:46 PM
1999 Triple Black Pontiac Formula Hardtop. Power Locks, Windows and Doors. Factory CD/radio, power antenna. Rear sets and belts removed but do have them still. Equipped with Viper 5900 Alarm with Remote start and Turbo Timer. Dark tint all the way around except windshield. Car is currently in need of a re-stall or a new converter. Trans is 100% and was just tested on the dyno and the fluid is nice and red, can send sample if needed. I'm gauging interest in selling it due to funds to repair it. I DO NOT have to sell it and will not accept low ball offers. I will post up some pictures and videos of it on the dyno very soon. I have owned the car for 3 years and all modifications were done while in my possession. She has been garaged kept its entire life and was driven by a young lady until I got it at ~76K miles. This car is my pride and joy for the track but school is just killing me and I think school/house is way more important than playing with cars. Thanks for the interest! :usa:
Performance:
Turbo kit by LSTurboPerformance/fenix999. 3in downpipe and system keeps AC. AC was removed during heads/cam install but have all accessories. Turbo kit was sprayed with ceramic paint and wrapped.
Turbonetics TC78 Turbo
TurboSmart Ultragate 38mm
Tial BOV 50mm
Alternator relocation kit from LSTurboPerformance/fenix999
Stock 346 short block
317 heads with stock valves
Comp Cams .650 dual springs/titanium retainers/7 locks
TSP Upgraded Trunion Upgraded Stock Rockers
TSP hardened 7.400 Pushrods
LS7 Lifters
LS2 Trays
EPP FI Cam
TSP LS6 Ported Oil Pump
LS2 Timing Chain Kit
ARP Cam retainer bolts
ARP Cam Bolts
ARP Head Studs
LS9 Head Gaskets
QTP Cutout with 3in Stainless Steel turndown
Speed Inc 25% Underdrive pulley
ARP Crank Bolt
LS6 Intake
Shaner S3 Ported and Polished stock throttle body
MSD wires with TR6 plugs
Throttle body bypass kit
Moroso Catch can with new PCV lines
160* Thermostat
Griffin vertical radiator
Flex-a-lite FLX-420 pulled fans cut to fit
Rossler T2 4l60E with vacuum modulator
Midwest 3800 stall *needs restall or replacement*
TCI flex plate
Hayden 11 in trans cooler with fan
TCI transmission pan with drain plug
Has 3 autometer gauges in AC vents(Boost, fuel pressure, oil pressure) and 3 on the pillar with 3 pod pillar from autometer (AEM wideband, water temperature, tranny temperature)
2 Walbro 255lb fuel pumps on a hobs switch and 60LB injectors.
Stock 10bolt with 2.73 gears, no whines and has hit 1.5 60fts
Tuned by Dan at Masport.
Im sure i'm missing some items..
Cosmetics.
Black Trans Am Front bumper with license plate portion cut for intercooler. No fog lights. Had brand new GM running lamp lens installed.
Black Trans Am rear bumper.
CCW Classics 17x4.5in front 16x10in rear(C5Zo6 setup) with black gorilla lugs
Hoosier DR's
C5Zo6 front red calipers/rotors/pads
6K HIDs in low beams
stock style VFN fiberglass hood
UPDATE: PTC Convertor and Nasty Performance Stage 3 Street Kit are here and will be being installed soon!
Performance:
Tial BOV 50mm
LS7 Lifters
LS2 Trays
EPP FI Cam
ARP Cam Bolts
ARP Head Studs
LS9 Head Gaskets
ARP Crank Bolt
LS6 Intake
160* Thermostat
TCI flex plate
Cosmetics.
Hoosier DR's
