416-418 LS3 guys, what # injector are you running?
I had planned 42s for my application I think for a NA motor that should be sufficent. I dont see any reason to go over 60 I think anything in that range will work once tuned.
Best think you can do is find out what duty percentage yours are running at full throttle right now to determine if you even need to change them. Remember Fuel injectors dont help gain horsepower, there only there to supply the correct amount of fuel, if you ever gain HP its cause your current ones are maxed out and causing your car to run lean
I think you will be ok, if your not over 80% duty at full throttle and max rpm you would be waisting money going bigger.
Unless you plan for a Dry nitrous kit in the future, but if you go wet you wont need to change them.
but if you ever go forced induction then you will need some really big ones
Im still not doing my swap till about october, but I did find some SWEET valve covors with Pontiac on them
Have you talked to MWC yet on your rear end. are you keeping abs and traction control?
I wont to keep mine so just wondering if you did on yours I emailed them and asked them if it was possible but never got a reply
