Which manual valve body to go with for a 700r4
I have a 95 Camaro with a 93 LT1 and 700R4 swapped into and was trying to figure which manual valve body i should go with.
I have the modified version of the TransGo 700-2-3 which you can make "full manual", and still use the TV cable. That way you will keep the pump alive, with smooth shifts at part throttle and firm shifts at WOT.
