Dynamometer Results & Comparisons - Stock bottom end LS7 goes 621/534... Graph inside
Ron@Vengeance
03-28-2011, 05:26 PM
For complete details on the build/previous results check out this post...
http://www.ls1tech.com/forums/dynamometer-results-comparisons/1388495-back-back-testing-ai-cncd-ls7-cylinder-heads-vs-stock-ls7-results-inside.html
After making 595/528 to the tires with CNC ported cylinder heads we upped the ante one more time!!
Adding an RPS Billet Carbon Twin Disc and an ATI 10% underdrive Dampner we netted 621RWHP/534RWTQ!!!! Not too shabby for a stock bottom end LS7!!!
VincesSS
03-28-2011, 05:50 PM
That's nasty.
ChucksZ06
03-28-2011, 05:53 PM
Great info. Is the RPS setup lighter than what was on the car? Thanks for test results.
blu byu EH
03-28-2011, 06:17 PM
Must keep this away from Dan.....................
ramairws6
03-28-2011, 10:43 PM
Damn Jake, where you been hiding out lately? Getting your car ready for the summer??!
gtodoug
03-28-2011, 11:31 PM
IIRC the rps setup shaves close to 30lbs off of the rotating assembly
Patrick G
03-29-2011, 07:06 AM
Awesome results. Bet the tune had to be tweaked quite a bit to keep the motor from dying at clutch-in compared to the previous tune. Light flywheels and clutches are great for performance but they can be a bear to tame on the street. Major props to Vengeance on another impressive build.
HioSSilver
03-29-2011, 11:49 AM
Impressive...My ls7 is on the way back together stock.....but this makes me think.
Stang's Bane
03-29-2011, 04:50 PM
Approximate cam specs?
ULTIMATEORANGESS
03-29-2011, 04:57 PM
nice work.
RJB01camaross
03-29-2011, 08:05 PM
Wow!!! I cant wait to play with a LS7 someday!!
93SlowBird
04-05-2011, 05:59 PM
nice build
S2VYSS
04-06-2011, 07:03 AM
Wow, amazing results!
0269camaro
04-07-2011, 02:44 PM
Very Niiiccceee
Ron@Vengeance
04-07-2011, 03:04 PM
The tune did require quite a bit of work to get drivability back after taking so much rotating mass off of the engine...
We are very happy with the results so far :)
HioSSilver
04-07-2011, 03:40 PM
Is that becuase of the cam? I have a tilton 5.5 triple in my camaro @17#'s for the whole mess and did'nt change the tune.
0269camaro
04-07-2011, 03:45 PM
My car could definitely use some tweaking here. I'm not going to bother though since I'm about to put a turbo on. The fact that you were able to tune out all the problems with all the work done on that engine is impressive. Well done
Ryne @ CMS
04-08-2011, 01:25 PM
on a c6 z06 is pretty basic to be honest.... add some timing in the idle coastdown table and some idle airflow in the higher rpm regions to bring the motor slower to idle and that is really about it.... i have tuned quite a few of these combos with great success
MYSTIC-1SC
04-08-2011, 02:57 PM
Very nice results.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
