Dlc?
Old 03-28-2011, 06:52 PM
deuce4935's Avatar
Default Dlc?
Anyone know why the dlc has to have a constant 12 volts instead of switched?
Old 03-28-2011, 08:58 PM
pdsq98gt's Avatar
So a scan tool can check module state. If you turn the key on, everything would wake up.
Old 03-28-2011, 09:57 PM
deuce4935's Avatar
So then its safe to assume that i wouldnt be hurting anything by using a keyed 12volt source? I want to avoid routing an extra wire from the vehicles interior out to the engine bay where the pcm is located.
Old 03-28-2011, 10:24 PM
01cherryreds10's Avatar
You'll be fine using ignition 12v. Most GM cars, the scan tool will stop communicating after a couple of seconds without the key on. Seems like the battery 12v is there just to verify the scan tool works.
Old 03-28-2011, 10:25 PM
pdsq98gt's Avatar
Yea you could. On most gm vehicles it is just on the same circuit as the cigarette lighter since that is hot all of the time.
Quick Reply: Dlc?
