daytime running lights
LS1Tech Administrator
Received 1,483 Likes
This link should help you:
http://xse.com/leres/ss/drl.html
This mod will allow you to disable DRLs and/or auto headlights for a Camaro.
Thanks I just unpluged the c2 plug since my brake light stayed on anyway and I found out why my lights stayed on all the time even when it sun shine the sensor on the dash was covered in dust like they sprayed the dash and never wiped the sensor. Thanks guys Now i just got to make a battery tie down so it can pass tech at the track.
If you take off your light control switch on the left side of the steering wheel there is an orange wire which you can simply cut and will disable your automatic headlights and daytime running lights....however you still will have your ambers on all the time when the car is on....
This is the route I went with...
