Advanced Induction 241's gain 41RWHP/32RWTQ (Stock Valves!)
Well, it looks as though all those internet experts are wrong again. 241's can make power.
This car isn't a world beater as far as #'s are concerned due to the baby camshaft and it's running through a GTO drivetrain, but this A/B comparison shows the potential of a decent combo and A.I.'s port work.
Details:
-2004 GTO M6
-Stock Intake
-Stock TB ported by Spartan
-Stock MAF
-Svede Ram air intake
-Pacesetter Headers/Off road mids
-Stock 2.5 piping with Magnaflow mufflers
-Comp 222/230 .560/.540 114 camshaft
-PAC 1218 springs
Previous #'s with this setup were - 384/368. Additions include:
-Advanced Induction CNC'd 241 castings
-Stock valves
-57cc chambers (Had miles of PTV room)
Final #'s - 425/400
The tach lead wasn't working for some reason and we had a hard time getting it to display RPM so sorry for the mph graph.
40+rwhp gains is on par with any aftermarket casting I've ever installed, and higher than most CNC'd GM castings I've installed. And this is just a 241. A.I.'s 243 program is even better. The best part, their pricing is EXTREMELY affordable.
FYI. I do not sell or distribute Advanced Induction Cylinder heads. Contact A.I. for more info. I believe they offer the absolute best quality at the most reasonable price.
Cheers....
Details:
-2004 GTO M6
-Stock Intake
-Stock MAF
-PAC 1218 springs
-Stock valves
Final #'s - 425/400
Cheers....
We're currently looking into a larger camshaft and better intake to go towards the 450-460rwhp range with these heads.
There's more than one way to skin a cat. Most of the internet crowd is only accustomed to one way of building compression or making power thanks to the great marketing teams of some parts houses/shops. The fact is, there's a ton of different ways.
every cc is worth around .15 compression bump roughly...241 is what 66.7cc to 57cc is 1.5 CR jump...
So if i had to ballpark the bump in CR was around 10-15hp...
none the less everyone should mill when throwing heads on, and if there is no room flycut...well my thinking anyways
awesome results everything i see on AI is top notch...
i was thinking 10 hp or so due to the bump in CR,according to my ricer math.but that shouldn't take anything away from the results,the thing to remember is this is with the STOCK valves..
good results!
good results!
These cylinder heads will shine much better once we get rid of the air restriction (LS6 intake) and go with a bigger camshaft that holds the valves open a little longer. I'd expect to see another 30rwhp out of this setup with a better cam and FAST setup. 450-460 is nothing to sneeze at through a GTO IRS drivetrain and heavy *** GTO wheels.
At the end of the day, I just build these engines. I don't sell the products.
LS1Tech Sponsor
Your results are about what we saw back in 04 with stock (good) ported heads and smaller Cams -we ran TR224's. The compression helps down low and the torque curve.
Problem nowadays is people instantly look at the peak hp #'s and not what actually makes the car move.So everyone put's in bigger cams.
