any words of wisdom for my header install on sat?
okay the time has come, i just have to man up and get this done, i got the FLP'S laying in the garage, got all the clamps and stuff, new gaskets, new plugs, 02 sims, and 02 extensions, im gunna be doing this on saturday at my dads body shop on one of his lifts. any tips or anything you guys have for me? any special tools i should purchase? or maybe some incourage meant for me.. haha, im 17 and this is gunna be my first real test of installing something difficult on my car.
Make sure your torque wrench works properly. My friend broke mine and didn't tell me. I ended up snapping a bolt off flush inside the head. I had to load the car up on a trailer and take it to a dealership. $500 later the bolt was out. Very expensive mod for me. Oh yeah... The same "friend" pulled the end of my new plug wire off when he removed it. Other than all that it went fairly easy. The hardest thing is removing the old stuff.
thanks alot guys, well i guess i was planning on doing this right then. i got all new plugs, and was gunna take the old ones out first, then install the headers, then put the new plugs in. also i bought oil and a new filter, so i was going to drain the oil and remove the filter before i installed the headers. also should i get a ratcheting 10mm wrench to remove the coil packs? and will that help with the header bolts at all?
step one get friend to help
step 2 buy beer(oops i mean soda your 17 haha)
step 3 BE PATIANT.... getting frustrated will cause you to mess things up and break thing... take your time it will go in it will seat it will bolt down....
if you are getting mad back away from the car....
calm down then start again...
