Anyone using BADZ's LCA's or PH Rod
Sweet Cheeks
How are they? I might make the switch. Would the weight savings be worth it? Also, they're adjustable and I don't know what to measure or test to know how long the LCAs should be. Any info would be awesome. Thanks.
Yep. LCA's. They look great - only can look right now as we still have like 3' of snow still. They will be installed next week with the rest of my winter buying spree. What I have read, on the LCA's: remove old ones; laid the new adjustables next to the old ones, make adjustables same length as old, re-install. That should at least give you a base. I know that they are a lot lighter than the ones I am presently running.
David
http://www.slotcarracing.com/itm00005.htm PHR
http://www.slotcarracing.com/itm00006.htm LCA
another picture of them https://ls1tech.com/forums/attachmen...ttachmentid=20
David
