Just got back from the dyno
Setup
TrickFlow As Cast 220cc Cylinder Heads- 3.90 Bore
Fully Assembled Including .650 Lift Springs
Mill to Desired Compression-61cc
Hardened Pushrods
228/230 .588/.592 112 LSA Camshaft
Comp Trunion Kit
GM MLS Head Gaskets
ARP Head Bolts
FAST Intake Gaskets
Front Cover Gasket
Front Cover Seal
Waterpump Gaskets
GM Crank Bolt
Powerbond 25% Underdrive Pulley with Gates Belts/GM Bolt- F Body
Comp Drop In Hi Performance Lifters
Katech C5R Timing Chain
Melling Hi Volume Oil Pump for LS Engines
SVO 42lb/hr Fuel Injectors
GM MLS Exhaust Manifold Gaskets
Poly Motor Mounts
Kooks 1 3/4 LT's
LS6 Intake
TSP 3'' True Dual Exhaust
426 HP 413 TQ
What you think?
Hardened Pushrods
Comp Trunion Kit
GM MLS Head Gaskets
ARP Head Bolts
FAST Intake Gaskets
Front Cover Gasket
Front Cover Seal
Waterpump Gaskets
GM Crank Bolt
Poly Motor Mounts
Kooks 1 3/4 LT's
LS6 Intake
426 HP 413 TQ
What you think?
seems kinda low. i made 420/395. with an MS4 fast92/PTM 92 and stock 853 heads. prob just the dyno though. many people dont know that chassis and engine dynos are actually used for disappointing people that just pent a bunch of money on their cars. numbers dont matter. how does it feel? got any vids?
i do all my own stunts errr uh work too
just ordered my buddies TSP tsunami
cam and other misc crap to put new lifters
in it.
post up a vid of the traction issues... maybe we can
help diagnose that problem....
lol yeah thats how feel too. As far as traction goes im thinking its just my stock suspension with that amount of power is not gonna cut it. I have nitto DR but they have about 12k miles on them so im sure there about done. Next mods are full suspension inc a 9 inch and a new clutch.
I'm not up with what an F/Body fuel pump flows but with the power you're now making it will be a wise choice to upgrade.
