Need Help!!!! Brake Problem.
Old 02-18-2004, 08:16 PM
goinbroke's Avatar
Default Need Help!!!! Brake Problem.
When i hit the brakes there is very little pedal before it feels like the pedal hits a brick wall. The pedal is not going to the floor and there is no air in the lines(already bled the brakes). The car does stop ok but i swear there should be more pedal before it hits the wall. Anybody know what this is? Is it a bad master cylinder? Any help is appreciated.
Old 02-18-2004, 09:59 PM
roy
roy's Avatar
Acouple of things come into mind
Abad brake booster
Alow vacuum signal to the booster
or frozen caliper pins
Old 02-18-2004, 10:41 PM
goinbroke's Avatar
How do you tell which one of those problems it is?
Old 02-18-2004, 11:25 PM
ta12sec's Avatar
Did you work on the car before this happened.
Old 02-19-2004, 07:58 AM
goinbroke's Avatar
I installed my heads and cam package.
Old 02-19-2004, 08:42 AM
ta12sec's Avatar
Make sure that you hooked the vacum hose up that goes from the intake to the booster.
