Ls1/t56 clutch issues need help
I'm currently in the final stages of my swap into my 71 nova and I've seem to hit a snag with the hydraulic clutch system..
Symptoms are basically the clutch pedal will not depress at all what so ever, almost to the point where the pedal flexes a bit!!!
Clutch system includedes
Spec stage 5 clutch
Wilwood m/c 3/4 bore with 1" of stroke
Oem recplacement slave cylinder
-4an quick dissconnect line
Any ideas would be greatly appreciated, I'd like to get this things on the road
Spec stage 5 clutch
I did that and it did stroke fine, I thought it could have something to do with the spacer spec includes in the clutch kit but I put the slave in with it and without and same result
I did that and it does move freely with the bladder open so where do I try and troubleshoot to find the problem
Pressure plate
Its easy to do, and from the sound of some of the tests you have done, but are you sure you the clutch disc plate is not installed backwards?
Pressure plate is fine and on correctly
The flywheel is a ls1 billet fidanza flywheel but I will try to get a mirror and light to see what's going on, thanks for the advice and help
sorry for not getting back so fast i found the problem it was a faulty master cylinder. after benching it i noticed it wasnt pushing enough fluid at all.
