Futral Fm10 Cam Vs Hot Cam
Thinking Of Going To Futral Fm 10 Cam Instead Of Hot Cam How Much Difference Would It Be? I Plan On Keeping Stock Heads So If The Hot Cam Will Make 370-390 Hp And The Fm 10 Will Make 390 To 400 Hp Would There Really Be A Huge Difference? I Will Have The Ls1 Edit Done After Cam Install. The Thing Is I Already Have The Hot Cam Kit And Im Just Debating On Selling It And And Buying This Cam.
Thanks For Any Help!!!!
You are comparing apples and oranges. The FM10 is a much more powerful camshaft than the hot cam.
If you only goal is to make 370-390 hp then stick with the hot cam. If you are looking for power under the curve or better track times the FM10 will be killer. My guess is the FM10 will respond very well to upgraded heads for even more power.
If you sell the hot cam...sell the springs too. Those FMS cams need a good spring.
