Cut Out Dyno on a Camaro 2010 SS LS3 ...
Old 04-03-2011, 10:46 AM
Brice's Avatar
Angry Cut Out Dyno on a Camaro 2010 SS LS3 ...
We've done a dyno day yesterday near Paris, France.
14 Cars, I've tuned a camaro 2010 SS on the street and then get to dyno.
Here is the comparaison dyno sheet. (The 2 two best of 6 runs (3 cut out closed, 3 cut out open).
(Tq is in NM, flywheel numbers on the comparaison sheet, the rwhp numbers don't appears on the sheet, a stock C5 is .. 349 fwhl this day, superflow dyno)
the PROBLEM is ... the higher numbers are CUTOUT CLOSED !
Too much back pressure ? we were shocked !
Mods : K&N airbox, ARH 1-3/4 headers, stock catback
any explanation ?
Old 04-03-2011, 10:50 AM
miami993c297's Avatar
A HPTuners log for each of those sessions might tell something...
Christian
Old 04-03-2011, 10:51 AM
Brice's Avatar
for information, here is a stock 2001 C5 on the dyno.
The dyno is proved and verified. The Red Curb is rwhp
Old 04-03-2011, 10:56 AM
Brice's Avatar
Christian
I haven't save the logs Christian. Nothing special. AFR 12.8, no KR ...
Old 04-03-2011, 11:00 AM
MAP/Dyn Airflow/Inj Duty cyc/IAT...everything egal???
Christian
Old 04-03-2011, 11:09 AM
Brice's Avatar
Christian
I don't have the logs.
I've street tuned with cut out open. Playing with timing on the dyno (15 minutes) and then we have dynoed with cut out closed.
I was so surprised !
I've just paid for dyno and the owner of the dyno shop's owner let me play a little with timing.
Has anyone the same results or I am the only one ? What are 'regular' gain ?
Old 04-03-2011, 11:12 AM
Brice's Avatar
I will dyno my corvette with cut out open/close.
By the time I've tuned it, I haven't got cut out. (Ti exhaust)
Old 04-03-2011, 12:31 PM
Without data, assumption can go from an extreme to the other...
My guess...temperature variation (engine oil, gear box oil, engine water...tires...) or Dyno manipulation.
Christian
Old 04-03-2011, 02:09 PM
Brice's Avatar
Christian
If I had the data ... I wouldn't need to post questions on a forum.
No it's not a temperature variation, we made 6 runs, same data (cut out open / close) and no dyno manipulation.
The real difference is cutout opened/closes. For information cutout closed are the last runs.
I've got 3 runs cutout opened, the data are the samed within 1-2 hp.
My best shot cut out opened is 438 fwhp ! it's a 15 rwhp loss !
I am the only one to have tested cut out on a LS3 ?
I think I have to rent the dyno 1 hour and find the reason.
Old 04-03-2011, 02:16 PM
1989GTA's Avatar
"My best shot cut out opened is 438 fwhp ! it's a 15 rwhp loss !"
Could be the location of the cutout. It might be in the worst posible location for exhaust wave tuning. Then again it could be something else. Hard to say without seeing it.
Old 04-03-2011, 02:17 PM
If I had the data ... I don't need to post question on a forum.
The curves shape are so parallel (from 2000 rpm to 4500 rpm...) that it is really looking like the Dyno Operator modified/adjusted the calibration between the runs...by purpose or by accident...it's a classic for anyone used to work on a dyno to see this figure.
And it's difficult to not say impossible to technically be affirmative on your case if you have no data to provide...and you can't be sure of temp/MAP/Dyn Airflow/Inj Duty cyc/IAT as long as you can't check them...
Christian
Old 04-03-2011, 02:18 PM
Demon 383's Avatar
Not suprised. Not all setups benefit from cutouts.
Old 04-03-2011, 02:20 PM
Brice's Avatar
Christian
The dyno operator have stayed in the car and I was besides him.
1 minute after the best run with cutout open. I told him : let's test without the cut out closed !
and here are the results !
I am agree with you but .. do you mean all the dyno sheets on the forum section are a total non sense without datalogs ?
Old 04-03-2011, 02:49 PM
Brice's Avatar
really ?
Old 04-03-2011, 02:56 PM
Brice's Avatar
Got it !
http://www.camaro5.com/forums/showth...t=53251&page=2
"I got a dyno tune and I lost power (5-10 hp) over the curve with the cutouts open vs the 419/401 with headers and tune, but that's not why I got them. I'm certain you would see more power over the stock tune on a stock exhaust"
Quick Reply: Cut Out Dyno on a Camaro 2010 SS LS3 ...
