TH400 Question
Old 04-04-2011, 08:16 PM
camaro_five0's Avatar
Default TH400 Question
I recently picked up a TH400 out of a '69 C-10 pickup to put into my '69 Camaro. Is there anything I need to change out in the tranny to make it run correctly in the Camaro? It doesn't need rebuilt, the transmission operates smoothly and the fluid is extremely clean.
Old 04-04-2011, 08:35 PM
SuperSlow02's Avatar
What engine is in it....if ls yes, you'll need a few parts to make it work... Look above and read the stickies for all the info
Old 04-06-2011, 11:35 AM
It's a 396. I know that you need a spacer plate for the LS motors, but wasn't sure if I had to swap out any parts on the transmission itself to go from truck to Camaro. Maybe the gearing in the transmission wouldn't be correct for the application, or I'd need a shift kit, etc.
Old 04-06-2011, 11:49 AM
garys 68's Avatar
The kickdown mechanism on the TH400 is electronic. It's operated off a swtch on the gas pedal. If you're old trans was a TH350, it had a cable.
Old 04-07-2011, 05:50 PM
Actually the original trans was a Powerglide, but I believe they're similar to a TH-350...
