WTB: f-body rear 12 Bolt, 9", dana 60
Im looking for a a built rear end for my 2001 camaro. The car is making over 500rwhp and the stock 10Bolt has broke twice. I would prefer a 9" or a dana 60, but a built 12 bolt will do the trick.
If you have anything to offer give me a call or shoot me an e-mail/PM.
(804) 731-3256 H2motorsports12@aol.com
I have a Strange 9" that I would like to sell. It has a spool with 31 spline axles and 4.11 gears. I sanded the entire rear end down and painted it with Black Sapphire Metallic and I also clear coated it. I painted the chunk aluminum to give it the look. I would take $1550 picked up in South Central Kentucky or if I have to ship it $1650 plus shipping. Let me know.
You looking to pick it up yourself or shipped. I'm in Pittsburgh pa. I have a 12 bolt from DTS with 4.11's 33 spline axles and a detriot locker I might get rid of for the right price. It's still in my car if that tells you anything about its condition.
It has not been narrowed and it is not in the car. It was in a LOW 9 second car on the spray and has not been installed in a car since then. It does need axle bearings. The rear has the option for resetting the lower control arms also.
It's stock length but your gonna need a torque arm which I have and a different drive shaft which I have. Are you gonna need the brakes? Your ten bolt brakes will bolt on it. I'll take $2400 for everything minus the brakes. It also has the aluminum back cover with the extra bearing supports in it.
PM me your number
Well the 4.11's aren't what I want in my setup, I want a 3.50 ratio. My car is supercharged and it's a M6. I'm buying a wavetrac also so either way I was gonna be selling the gears and the locker for starters. I've been thinking about spending the money for a fab 9. It uses its own torque arm and driveshaft, so might as well sell mine if I can't use it with the fab 9.
I pm'd you my number and answer. I do have a chromoly driveshaft for 4L60E and I believe will also fit T56 as well, but not sure. For that price, the driveshaft is not included. I will let the driveshaft go for $250 though.
