Dropping V8 into a v6 body?
Well i'm currently looking for a decent roller and all i can find thats not way overpriced (4k+ -_-) is v6 bodys. I have a Ls1 / t56 currently from my formula that was in an accident, and since the frame rails are bent/crumpled iv'e been browsing around before i take it to a frame shop.
I'm currently looking at a 98 black v6 body and the dude wants only 1500 for it, in great condition with good title and still runs (rough though).
But all in all, How big of a job is it replacing the v6 with the v8 (wiring/mounts/ect?)
Any input is appreciated, thanks
- Colin
- Colin
its not hard at all i did a swap before on a 2000 firebird and put an ls1 in it. i had to get a new k-member i got a bmr one, you don't have to change the fuel system, you can keep the v6 d/s. I'm having a hard time remembering, but it wasn't hard its basically plug and go, just get the engine ecu harness and trans and your basically good to go almost.
Internet Mechanic
Like what I was stabbing at. With the new harnesses out there most capable can get the swap done, but doing it "right" will take time and effort and $$$.
FYI LS Fbodies have been dropping their values like crazy, older stuff going in the 5's to 8k and even 2002's bearly getting over 10k.
Considering now I think ill just have the car put on a frame machine and forget about the roller idea.
Thanks for all the info, input. A+
(very good guide btw merv)
Colin
Colin
Cradle, maybe the Trans Crossmember, Steering Rack & Linkage, slightly modify Fuel System, Engine Wiring Harness and PCM. If you want to get picky then the Cluster.
Not really that bad.
Thanks guys.
None of mine have ever made it to sticky's..I think I'd make too many of the Sponsors cry..
check the for sale someone has a 99 roller ta . i didn't check the price. and btw my buddy just bought a 00 white trans am with 99970 miles , a4 with gmmg and intake for 5800 . So if you look their are deals . Look around and be patient , we had to go 7 hrs away with truck and trailer but he got it .
It wont be so hard since you have a donor car , many people have done this with ease.. believe me If I found an LS1 donor car , Id jump all over it so I could drop a V8 in my car ..
Internet Mechanic
See here is the thing with that.
In Connecticut we need to have a scanable emissions test for ANYTHING 1996+ as the switch to ODBII was made.
Anything 1995 OR older must got on a roller emission.
Since this VIN of the v6 car is for v6 emissions, you may get screwed with your trying to do this swap. We had a guy throw in a GM ODBI style motor in a 2002 BMW and since the computer does not communicate he could not complete the registration process and had to find another complete ODBII complient swap!!!
To say the least!
To say the least!
Pontiacerator
It's not about "dropping an LS1" into a V6 car, as much as it is dropping a V6 car over an LS1 powertrain. In other words, the idea is to get an LS1 powertrain drop out, complete with the K-member and wiring, and hoisting it up into the V6 body. Do a search and you'll see the complete story regarding wiring, PCM, fuel system, gauges, etc.
