m6 --> a4 swap q? regarding wiring harness, firewall holes
Old 04-05-2011, 09:01 PM
evo462's Avatar
Default m6 --> a4 swap q? regarding wiring harness, firewall holes
Two questions...is the wiring harness that is transmission specific the "in car" harness? How did you plug the holes in your firewall where the master cylinder once was?
Sorry if these a dumb questions! I am on my phone and it makes reading through a 30 page thread difficult.
Old 04-06-2011, 05:59 AM
cabel1's Avatar
The engine harness has the trans wiring in it. As far as the inside there are only a couple wires to run to the shifter.
As far as the hole, I'm still working on that.
Old 04-06-2011, 12:51 PM
sheikss's Avatar
You can use anything flat to cover the whole. Some sheet aluminum would be a good chiioce, just make sure you seal it alittle, I used rtv.
