15x10 Weld Prostars lugnuts?
Old 04-06-2011, 04:15 PM
philsblwnz28's Avatar
Default 15x10 Weld Prostars lugnuts?
Ok I am thinking about ordering the weld prostars for the rear of my z28. I was wondering if these lugnuts can be used on the stock studs? Thanks
http://www.summitracing.com/parts/MCG-63016/
Old 04-07-2011, 10:29 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
That is the correct thread size but I would call Summit and make sure they will work with the Pro Stars. Also if you have extended studs you'll need open ended lug nuts
Old 04-07-2011, 11:00 AM
wheelczar's Avatar
Default Weld Lugs
Make sure that you use the large chrome plated concave washer. This is helps spread the load and also maintain torqu specs.
McGard lugs are the best.
Quick Reply: 15x10 Weld Prostars lugnuts?
