can trans fluid be too cool?
Old 04-06-2011, 07:08 PM
SexyTransAm's Avatar
Default can trans fluid be too cool?
just got my temp gauge hooked up and drove bout 10 miles on top of the 8 it took to get home to hook it up. and after the drive the temp gauge ( auto meter pro comp) was a lil under 150. im running the stock cooler into a ext. cooler, and have a 160 t stat. so is it too cool?
Old 04-06-2011, 08:58 PM
SPRAYED 01's Avatar
That's perfect. Be glad its that way
Old 04-07-2011, 02:37 PM
its just wild to see it that cool. i knew it would be cool but not that damn cool
Old 04-07-2011, 04:47 PM
BODUKE's Avatar
Thats a good temp.
Old 04-07-2011, 09:00 PM
senicalj4579's Avatar
Hell no it cant be to cool. 160f is a GREAT temp to run at all the time. I run my ext cooler as a stand alone and even when I drove it in the begining of last winter it was fine. Trans temp would be 30f or below at startup and I would just give the car 5-10 min to get coolant temp up and by that time trans temp would be about 50f.
Old 04-08-2011, 09:36 AM
FastKat's Avatar
Like engine oil, I think trans fluid does have a minimum recommended operating temp. From what I've read, that temp is around 160* F.
