Are all L92 valve springs the same? Do L92 springs work w/LY6?
I want to replace one of my stock valve springs, and I see pace has L92/L76 valve springs at just over a couple of bucks and I want to know if this also works for my L96 (LY6) engine? Anybody know?
thx!
thx!
I'd call MAST or TSP.
I was able to have the GM online store look up the right one, so I'm covered. It was only a bit over $2, so I ordered one to replace the one I have w/a bit of rust on it from oil cap off in case I keep stock valve springs. Anybody know how much lift the stock beehives are good for? Mast said I didn't need new springs with the mild cam they have for my L96; would love to believe that.
The L92/LY6/L76 all use the same spring, 12589774. Specs are below.
12589774 CK2, 3 6.0-K/N (LY6)
12589774 CK1 4.8C (LY2), 5.3J W/CYL DEACTVN (LY5), 6.0Y W/CYL DEACTVN (L76), 5.3-M ALUM W/CYL DEACTIVATION (LH6)
12589774 CK1 6.2-8 H/O (L92)
12589774
valve Springs
(not shown)
• Beehive style springs
• Standard L76/L92 springs
• 1.800" installed height @ 90 lbs.
pressure
• Max lift .520"
• 1.300" @ 264 lbs. pressure
