How do I make my ss camaro a 11 second camaro???
I'm looking to make my car run in the 11s, it is completely stock ls1 with a 6 speed so I need as much info as I can get. I want the best from the exhaust, intake, cam and head combo, throttle body, suspension. Any information will help thanks
Easiest route as well as cheapest.. 9", clutch, 150 hit, tune, sticky tires..
Or...
Mid size cam. Around a 230/232 .600 112
If not 01-02 ls6 Intake
Full exhaust
tune
9"
Sticky tires
Few other odds and ends.. under drive pulley, springs, push rods, etc, etc..
BTW.. u need to do some research, u have a looooong way to go
Or...
Full exhaust
tune
9"
Sticky tires
I already said nitrous gears tires and rear.. I was being sarcastic but I wasn't joking at the same time lol.. It's honestly like Somone said the fastest cheapest way.. Of course I said a 250 shot because I wanted to make sure you hit 11's.. Lol but ya do a search.. Our cars run in the 9s for Petes sake depending on you'd cash.
If money is no object then buy a dng zr1 vette and pulley and tune it...
is it 6 speed?
My friend in his ws6 did this and ran 11.8
MS3 cam
4.56 gears
stock rear end
tuned
pacesetter LT
lid
he launched it kinda hard around 5000
and make sure you can drive
MS3 cam
4.56 gears
stock rear end
tuned
pacesetter LT
lid
4.56 gears and a blys ply tire help greatly. 4.56 gear and a 10 bolt rear dont mix. So if you upgraded to a 9 inch rearend for reliablity with a 4.30 to 4.56 gear and bolt ons and a cam and launch it like you mean it. 11s are easy. but that is if you want to stay N/A. Nitrous would be the cheapest, Just how you want to go about it.
a ls6 intake and a polished TB.TSP prc heads,ls6 st1 or 5.3 st2.5. a torquer v2 cam pkg. long tube headers with a after market Y-pipe, and a good flowing cat-back exhaust system.after market lower control arms and a adjustable torque arm.maybe bigger injectors and a good tuner.just some ideas to start considering.you don't need a big cam to run 11.XX,just a well thought out combo.
Or do like the Honda guys .. Gut the whole car use an empty bucket for a seat cut of integral parts of the Chasis and frame, use an gas weed blower as a turbo etc until you cut 1000 lbs off your car and there's no way for it to pass tech... I've so seen some ratted out gutted civics on you tube that make me want to shoot myself
On the real. Head cam intake weight reduction tires and gears... It's not cheap to build an 11 second fbody that's reliable...
