T5 on a 5.3 help
T5 on a 5.3 help
has anyone mounted a T5 to a 5.3? i am doing an ls conversion on my c10 an i am running a 5.3. i already have the t5 an would like to know if anyone makes an adaptor plate or is this not possible?
thanks
thanks
^ I was gonna say something similar, but I didn't want to be too harsh. But in a truck, it may be ok depending on gear choice and tire height. But the T5 has a horrid RPM dropoff and with 4.11s it may top out at about 95 in a car. -My buddy found that out the hard way in his Fox. Never saw a T56 in a truck though.. That'd be pretty cool for a muscle truck.
As for the T56 in a truck issue, Dodge came out with one years ago called the SRT10 Viper truck. I have seen a Lightning with a T56 and even sold a T56 to a guy putting one into a Suburban with 33" tires!!!
Not to mention a truck is about 1000 lbs heavier than most cars the T5 came in from the factory. Thats going to decrease its torque capacity.
You might want to determine what year and engine because there are at least 2 bellhousing patterns, 2 input lengths, 2 spline count/sizes and a whole lot of different gear ratios depending on which one it is.
Everything can be made to work. You're providing enough information to determine absolutely nothing. There's a 1352-xxx number on a decal up top or on a metal tag at a tailhousing bolt that would help enormously.
