weld RTs ???
Old 04-08-2011, 05:41 AM
kevins2000LS1's Avatar
Default weld RTs ???
Guys are u running these 15x10s on a 5.5 on stock brake calipers? Going to pull the trigger today and order a set and wishing I'd get a answer. I know the 7.5bs clears
Old 04-08-2011, 06:22 AM
ssman00's Avatar
15x10 require a 7.5bs and the 15x8 use the 5.5bs. So a 15x10 with a 5.5bs would be incorrect for ur car if its a stock length rear.
Old 04-08-2011, 06:32 AM
I have a narrowed 12bolt 2" per side
Old 04-08-2011, 08:50 AM
wheelczar's Avatar
Default 15x10 5.5 Back Space
All of the Weld RT-S wheels in medium pad will clear the stock brakes. Back spacing will not play a role in clearance. Post the pics when on!!
Old 04-08-2011, 10:38 AM
GMRACER13's Avatar
15x10 with 5.5 BS on a rear narrowed 2" per side might stick out a little. I run the same wheels on my car and it's narrowed 3" per side and the wheels just tuck under the fender.
Just picture the rear wheels on my car moved out another inch and that's what yours will look like.
Old 04-08-2011, 10:42 AM
Zmg00camaross's Avatar
^^^ is that the WELD rts front wheel, or what wheel is that.
Old 04-08-2011, 10:44 AM
GMRACER13's Avatar
No, Aluma Star 2.0 one piece wheels on the front. The rears are RT-Ss.
Old 04-08-2011, 11:01 AM
I knew they where differnt. Guess the fronts arent very streetable. But they look great.
Old 04-08-2011, 06:44 PM
SmokedOutZ28's Avatar
Yes they will fit, I run the same wheel with Stock LS1 rear calipers.
Quick Reply: weld RTs ???
