How to Modify Spectra EFI tanks to prevent fuel starvation?
Old 04-08-2011, 04:32 PM
aarroyo87's Avatar
Default How to Modify Spectra EFI tanks to prevent fuel starvation?
I bought my 1965 Chevelle EFI tank 2 years ago and inside the tank is a sump. Even with the sump, my engine starves for fuel when low on gas and while making everyday turns on the street. I've been searching Ls1tech and the Chevelle forum but i have yet to find a solution for me. My tank has been used already, so cutting and welding it requires some work that has to be performed by a radiator shop. Is there a way to modify the tank / sender without welding it?
Old 04-08-2011, 05:42 PM
usafws6's Avatar
get a surge tank. it will hold a small amount of fuel so the the motor wont starve. cxracing.com is where i got mine.
Old 04-08-2011, 06:05 PM
aarroyo87's Avatar
I have seen that surge tank before. Don't you have to run an external pump with that setup? I'm not a big fan of external pumps because of the noise. I like the idea of a surge tank. Only if I can fit one into the existing hole I have.
Old 04-08-2011, 07:35 PM
usafws6's Avatar
you do have to run an external pump. i dont care for the noise either but its better than fuel starvation.
Old 04-10-2011, 09:55 PM
flywheel's Avatar
There's been all kind of talk about these tanks, but havn't heard of any cure. I wish there was. Im in the same boat. Just haven't filled mine with any gas yet, but will need to soon. Mine is about 2 yrs old, so no warranty..
Rick
Old 04-11-2011, 09:07 AM
Jimbo1367's Avatar
I plan on baffling my Spectra EFI tank in a few weeks of so. I'll take pics.
Old 04-12-2011, 12:18 AM
aarroyo87's Avatar
Today I bought a used fuel pump assembly from a 1998 GMC Savana for $20. I bought it to understand how it works and hopefully use some of the parts on it to use on my home brew in tank sump canister.
I also considered baffling mine also but I'm not sure if there a way that actually works.
Old 04-13-2011, 10:56 PM
aarroyo87's Avatar
The hole is too small to make a canister sump. I'm going to order a regular tank, cut it and put a ford F350 pump assembly into it? Any one interested in buying a regular 65 Chevelle tank and an EFI tank? I'll give you a good deal!
Old 04-14-2011, 12:28 PM
thunderstruck507's Avatar
How do you set up a surge tank? Looks like there are several in/outs on them...
Old 04-14-2011, 01:16 PM
aarroyo87's Avatar
My in tank surge tank idea would work like this.
http://www.ratdat.com/?p=168
the only difference is that my idea would be inside the tank. The fuel sump / canister would be filled using umbrella valves and the return line instead of a second fuel pump.
Old 04-14-2011, 01:43 PM
Jim Maras's Avatar
Pisses me of that Spectra sells a tank designed for EFI that does not work properly. THEY should be coming up with a solution to the problem!! Guess that is too much to ask, a company to correct their design flaw. I, like alot of people, had not even installed my tank before the waranty was already up.
Old 04-16-2011, 11:44 PM
flywheel's Avatar
Ditto to that Jim. In the same boat.....
Old 04-17-2011, 07:03 PM
Jimbo1367's Avatar
Me three
Old 04-17-2011, 07:13 PM
Bowtie70SS's Avatar
Plenty of companies selling junk and getting away with it. I have one of these tanks as well and I suppose when the time comes I will be either modifying or replacing the tank.
Old 04-17-2011, 08:07 PM
aarroyo87's Avatar
I'm curious to know how many people have bought these tanks. I might have to give them a call to see if they can supply a fix.
Old 04-18-2011, 07:28 PM
flywheel's Avatar
I called on 2-24-11 and spoke to a guy named John (tech dept) and he said there's not a problem. It's been blown out of proportion according to him.. He told me just put it in and not worry about it... He wouldn't even tell me what pump is on it or where i could get one other than calling them to get one.. Which doesn't do me any good if it happens on a sunday when Im 900 miles away in Nashville. That kinda ercked me!
So, I dought they will admit any wrong! If there dealers quit buying it they may just drop it from there line!
Rick
Old 04-18-2011, 07:52 PM
Blue67LS2's Avatar
Angry
I bought mine from Rick Auto a little over a year ago. The fuel pump went out shortly after the initial test drive. This common issue, along with the well publicized starvation matters, prompted me to seek a return / refund. I spoke with a supervisor at Rock Auto who allegedly contacted Spectre regarding my request and was told they won't do anything if the tank is outside the 1 year warranty period.
I asked about exchanging it for the "new and improved" tank and was told Rock Auto no longer carries Spectre tanks nor do they have any plans to do so in the future. I got the impression they were tired of fielding calls such as mine and are now distancing from the product altogether.
I too am amazed that there is no recourse for selling a faulty product...
Old 04-18-2011, 08:28 PM
usc2001gc's Avatar
Rock auto still has a listing for the Spectre tank for my Chevelle. Maybe they're still getting rid of the on hand inventory. I've had starvation issues will fuel level right around 1/2 tank.
They should be required to make it right. Maybe a class action lawsuit by all of us "make believe" starvation issues owners.
I think mine is still within the one year window. How much of an issue is it trying to ship a used tank back? I would think there would be issues with the carrier for transporting a used fuel tank.
Old 04-19-2011, 09:13 PM
flywheel's Avatar
Blue67, what did you do about the pump? Where did you get another one? You have to get it from them?
Rick
Old 04-20-2011, 07:27 AM
Blue67LS2's Avatar
I went with a Walbro 255 per the recommendation of several on here. I did not purchase it from Rock Auto.
Quick Reply: How to Modify Spectra EFI tanks to prevent fuel starvation?
