FlipediS
04-08-2011, 04:38 PM
Well i saw an add on a local craigslit out here in Hawaii. for this WS6 for 6k. With only 33k miles. And figured it was way to good to be true. Almost didn't even respond to the add because it was on another island. But i did, Next thing i know i was flying over to take a look at it. And buy it and put it on the boat back to the big island. Well when i bought it i was told it had exhaust and a system in it. And the vette rims with the 315's in the rear, Then found out they forgot to mention that there was a 3500 stall in it. So figure that was a bonus.
Then once i got it home i crawled under to car to find out it has BMR, BMR subframe connectors, BMR tubular LCA's with LCA relocation brackets, and a TA girdle diff. cover, Front KYB adustabel shocks, And i believe a racetronic fuel pump. Looks like there wiring ran to the fuel pump. Pace setter headers, And hooker cat back, And thats what i have found so far. Thinking that might just be everything. Also has a twisted insanity, Nitrous controller mounted inside. Witch they fabed up the center conceal for it. But is not hooked up, Was thinking about removing it. However would have to replace the center counsel if so.
So im thinking i got a good deal for 6k on an 01 ws6 with 33k original miles?
Only bad thing is on the hood there is some spots where the clear coat bobbled up and needs to be fix. as well as one small spot near the gas tank. And a little dent there as well. Other then that she is clean and beautiful!
http://i6.photobucket.com/albums/y220/FlipediS/P0001_180311.jpg
http://i6.photobucket.com/albums/y220/FlipediS/IMG_0033.jpg
http://i6.photobucket.com/albums/y220/FlipediS/IMG_0022.jpg
http://i6.photobucket.com/albums/y220/FlipediS/IMG_0021.jpg
http://i6.photobucket.com/albums/y220/FlipediS/IMG_0029.jpg
http://i6.photobucket.com/albums/y220/FlipediS/IMG_0015.jpg
http://i6.photobucket.com/albums/y220/FlipediS/IMG_0012.jpg
http://i6.photobucket.com/albums/y220/FlipediS/P3080637.jpg
http://i6.photobucket.com/albums/y220/FlipediS/P3080636.jpg
http://i6.photobucket.com/albums/y220/FlipediS/P0004_040311.jpg
http://i6.photobucket.com/albums/y220/FlipediS/1.jpg
