LS7 install ChevyII Wiring & oil pan
First have issues with the wiring from GM.
The kit is completely assembled , I guess there assumption is there is no firewall! (I should know, I used to work for the "A")
Any way, what firewall bulkhead pin adapters have anyone used.
FIRST! no way in hell am I using the one from Painless.
Any ideas? I have found a few, just searching for good ideas!
Second, I have oil pan issues with the dry sump.
I have called ATS and also e-mailed them with no response fo specifications yet on there pan.
Any other known options for the dry sump LS7 engine?
Thanks
guys.
Al
Clearance issues with pan.
Thanks for the garment there GM, guess i will shrink the plug in hot water to make it fit! Dumb "A" !
Hole for the plug will be larger than the garment.
1967 ChevyII Chassis Works front clip, LS7 & 4L85E Supermatic transmission.
Thanks
guys.
Al
