Rear end
Old 04-08-2011, 08:31 PM
95 Firebird's Avatar
Default Rear end
I have a 95 firebird formuka with a 6 Speed. Could anyone tell me what rear end is in it? I need to know so I can order gears for it? thanks
Old 04-08-2011, 09:00 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Put your VIN in here. Look up the G option code.
http://www.compnine.com/vid.php
Old 04-08-2011, 09:21 PM
rbaksi's Avatar
If it was 6 speed stock, it should be 3.42s. Look on your RPO sticker on the door or in the glovebox. GU2 = 2.73, GU5 = 3.23, GU6 = 3.42
Old 04-09-2011, 05:54 AM
Thanks for the help. I know it has a 10 bolt but I also need to know what size carrier? Is there a way to find out without tearing it a part? Thanks
Old 04-09-2011, 06:48 AM
Paul Bell's Avatar
Go to:
-The LS1Tech homepage which shows all the sections.
-Go to the Gears and Axles section.
-Go to first thread, the sticky titled "Your questions are answered in here! Look here first!"
-Go to the first link in it titled "Rear end faq!"
-Read all items.
Old 04-12-2011, 05:35 PM
That was very informative but still did not answer my question. I need to know what size ring gear ( as far as 8.5 in or 7.5) to order from Jegs is there a way of finding this with out tearing the rear end apart? thanks for the help.
Old 04-12-2011, 08:20 PM
2002 T/A's Avatar
Call the GM parts counter? I think it's considered a 7 5/8".
Old 04-12-2011, 11:44 PM
Paul Bell's Avatar
The rears in these cars has a 7-1/2 inch ring gear.
Any seller or website (like Jegs or Summit) would've told you what size the gears are.
Are you planning on doing a ring & pinion install? If so, you have a lot to learn if you didn't even know the rear size. This installation is pretty involved and certainly not for the inexperienced.
Old 04-14-2011, 07:59 PM
2002 T/A's Avatar
Sorry, got that mixed up my Jimmy
Quick Reply: Rear end
