wut stall
wut stall
I have a 2000 SS and I'm gonna be running MS3 cam set up.
Mostly street use maybe the track a couple times. I don't really know much about stalls,but I'm lookin for drivability but with enough empf to get the job done.
We have several options for you and would love to help. Can you fill out our "Ask Chris" form, link is in sig. That will give us the info we need to spec a converter. While a 4000 might be best for the track, it can be a bit much for a DD with minimal track visits. So it really depends on how aggressive you want to get. Looking forward to hearing from you.
Chris
Chris
Depends on what you go with. Fill out the "Ask Chris" form from Circle D and they can tell you how much and what stall will be best for you. I just mentioned Yank because the cam you are asking about is close to my friends cam, and he ran a Yank converter. I'm going with a Circle D for my next converter.
the converter has a lock up clutch,which acts like a 5 gear. .4000 rpm is the flash rpm if you mash the gas.get a good tranny cooler and a deeper pan.how many miles on the trans?
