Removing Trans with Solid motor mounts??!!
Old 04-10-2011, 11:11 AM
Bryceslu's Avatar
Default Removing Trans with Solid motor mounts??!!
My slave died on me and I started tearing into everything to replace it.
Well I got it torn down to the 8 tranny bolts but for the life of me couldnt get at the top pass side bolt.
I couldnt get a socket or extensions even to it as the top of the trans was too close to the bottom of the car.
This must be due to having solid motor mounts and there being NO flex to anything...the trans does not drop AT ALL when not supported.
Has anyone pulled the trans on a car with solid motor mounts? if so HOW THE F did you do it??
Would I be able to drop the K member at all to lower engine/trans to get at it?
Otherwise im screwed here with a car that I cant drive!
Old 04-10-2011, 11:42 AM
Kleeborp the Moderator™
MeentSS02's Avatar
You'll have to lower the k-member.
Old 04-10-2011, 11:47 AM
Blwn_by_Twins's Avatar
Have you tried getting at it from inside the car? Through the shifter hole.
Old 04-10-2011, 02:01 PM
Bryceslu's Avatar
Ive done a bunch of searching with no luck...
Any how to's on doing this?
Or link to a writeup somewhere?
Thanks!
Old 04-13-2011, 02:15 AM
Mattsv8's Avatar
Why can't u loosen the motor mounts to let the motor move
Old 04-13-2011, 06:13 AM
Bryceslu's Avatar
Motor mounts are solid. would have to take them completely out.
Old 04-13-2011, 06:32 AM
jsteele90's Avatar
lower the k member. only way i see it happening.
Old 04-13-2011, 09:12 AM
Grifter's Avatar
Yup. I installed my clutch with solid mounts, just lower the k member until you have enough room.
Old 04-13-2011, 01:00 PM
Bryceslu's Avatar
Yeah that is on my plate for this weekend.
Just the 6 bolts for the K right? anything else I should disconnect/watch out for?
I am hoping I can get by with only lowering about an inch or so.
Old 04-13-2011, 04:15 PM
Sargeant Sh!tbag's Avatar
Yes, there are 6 bolts.. You will have to completely remove the 2 rear k bolts as they are pretty short. It will easily lower an inch.. I had to lower mine after being a tard and forgetting to hook up my steering shaft after reinstalling my K and everything else when some motor work was done. I didnt notice any stress on anything. I would just loosen the steering shaft bolt up top if anything. Coming strait down it doesnt have much give. All the other stuff will have enough room for movement that you wont have to worry. Things to watch if you want to be picky would be the power steering lines to the rack, and the front brake lines in the plastic retainer on the drivers side. They shouldnt be an issue as mine werent but you never know.
Old 04-13-2011, 04:24 PM
RsSean's Avatar
If you dont want to mess with that take the intake off and you can get to the top bolt with ease. Then but the intake back on and do not re install the bolt.
Old 04-13-2011, 04:35 PM
Dont do this.......
Old 04-13-2011, 05:24 PM
Bryceslu's Avatar
Thanks! Hopefully I can finally drive my car again after this weekend!
Old 04-13-2011, 05:30 PM
ivan_key's Avatar
I just changed my mind on getting solid motor mounts lol
Old 04-13-2011, 05:53 PM
Bryceslu's Avatar
Yeah if you dont have to then dont! polys are more than fine for almost all applications.
I had to go solids due to headers fitting like ****...thanks LPP
Old 04-14-2011, 12:07 AM
HMM, this is odd.. I am running LPP SS LT headers and have no issues running my poly mounts.
Not to change the subject here but what was the issue?
On a side note. Make sure you use a jack on the K as you loosen the bolts.. If you loosen them too mcuh you could be crushed by the K falling on you.. It is hard to tell how much the bolts will thread out before running out of bolt.
Old 04-14-2011, 06:46 AM
Bryceslu's Avatar
Pretty much everywhere...1 side was under, 1 side was on top and 1 side was against the motor mount pedestal.
Driver side was up against the lip on the K or a arm housing whichever that is, so I had to saw that off. Other side was resting against the pedestal of the motor mount.
Pass side was sitting on top of the K or a arm housing whatever it is.
OH and yeah I planned on not trying to kill myself.
Old 04-15-2011, 12:41 AM
Crazy man!! Mine were a perfect fit. I didnt even loosen the motor mounts to install them and didnt have to cut them.. I would have pitched a bitch on the phone with LPP.
Old 04-15-2011, 07:19 AM
Bryceslu's Avatar
Oh trust my I tried to work something out with Carl...sent him pics and everything.
but heres the response I got 'Please read our Terms and Conditions again.
Thanks, Carl'
And then no response
Quick Reply: Removing Trans with Solid motor mounts??!!
