Will these fit stock height Camaro
Old 04-10-2011, 02:43 PM
Richuk's Avatar
Default Will these fit stock height Camaro
Can someone tell me if these will fit a stock height 98 Z28? I dont want to do any cuttign etc, They'll be coming to the England so a long way to send them back if they don't!
Also, you can get this wheel in 17 inch front and 18 inch rear, Any reason why you would get different sizes?
Thanks
http://www.oewheelsllc.com/Wheels-fo...25822-3-1.html
Old 04-10-2011, 03:18 PM
cemlsx's Avatar
different sizes are usually for creating a raked stance , no handling benefits , you shoudnt have any problems because of your height , stock or lowered , if you run really wide tires you might need to hammer the wheel wells a little bit but you nothing so major that youd need to send them back ! glad to see F-body's in the UK , hoping to bring mine this summer ..
Old 04-10-2011, 03:32 PM
Captain Double Post
BOBS99SS's Avatar
Yeah if anything just a lil bfh mod,that's not a big deal what so ever
Old 04-12-2011, 01:16 PM
808z28camaro's Avatar
Grinding down the bump stops is HIGHLY suggested. Not sure on a stock hieght car but i think BFH mod is a must.
Old 04-12-2011, 01:23 PM
babbage1109's Avatar
I have my car dropped 1.25 inches and I can fit those 18x10.5
Old 04-12-2011, 02:20 PM
99Bluz28's Avatar
The 18 x 10.5's w/+56 offset will need: BFH on inner fender well, trimmed bump stops, and a adjustable PHB. The reason for this is the offset, a +45 to +50 offset is what you really want for the best fitment. If you don't want to deal with this then just get 18 x 9.5s for the rear also.
Old 04-12-2011, 05:10 PM
It also depends what size tires you will be running in the rear. I have 315s. I had to trim out fender, grind bump stops sever millimeters, bfh inner fender (alot since im lowered 1.75). run 1/4 spacers, longer shank lugs (since i didnt get longer studs)
