Cooling fans in 1st gen
Old 04-11-2011, 01:31 AM
67Firebird455's Avatar
Default Cooling fans in 1st gen
Doing a turbo 4.8 (for now, have a 6.0 waiting) with TH400 and 9" in my 67 bird. Getting closer by the day, but running into an issue with cooling. I picked up one of those Jegs "rip off" LS1 into 1st gen F-body radiators, I swear, it looks like every other piece of junk Chinese sold radiators on Ebay. Anyways, long story short... I don't have any cooling fans. The core measures 22" wide, 17" tall. Would a 3,000 rpm (just over 3,500 CFM) 16" fan work to keep this thing cool? What do you all think?
Old 04-11-2011, 03:45 AM
usafws6's Avatar
Go dual fans to be safe
Old 04-11-2011, 08:18 AM
scatillac's Avatar
Staged OEM LS1 duals (and radiator) here, but my swap is N/A.
There are several aftermarket guys who make OEM LS1-compatible heavy duty all aluminum radiators that will work should any cooling issues arise.
Attached Thumbnails Cooling fans in 1st gen-ls1_rad.jpg   Cooling fans in 1st gen-ls1_rad1.jpg
Old 04-11-2011, 04:05 PM
Hmmmm, I was seriously considering the ls1 style radiator and fan setup because it's got the shroud and everything. The fans are just so bulky I was concerned with the exhaust under them from the drivers side heading to the passenger side where the turbo will be placed.
Thanks for the advice guys.
Old 04-11-2011, 04:27 PM
Steve68's Avatar
Crown Vic fan 5000 CFM, thats what you want
Old 04-11-2011, 05:07 PM
69 Ghost's Avatar
Cheap chinese F-body radiator about $60 delivered and a set of stock F-body fans works great. If you go with a Crown Vic or really a Lincoln Mark VIII fan setup. Only problem with those is you need a 60 relay for those fans they will blow a 40 amp fuse every time.
Old 04-11-2011, 06:04 PM
Yeah I've seen those Mark VIII setups, it's a bit tall too. My radiator measures 17" vertically on the core, and 22" so I'm kind of limited, it's just pretty thick.
Quick Reply: Cooling fans in 1st gen
