FAST 102 Lsxr fuel rail/injector options
I am getting a FAST 102 for an LS1 and need to know what options I have as far as injectors and fuel rails. I understand that I need to get the FAST fuel rail kit to use my LS1 injectors, but do I have any other/cheaper options? I will be getting new injectors regardless because I am doing a H/C swap.
Fuel Rails-
FAST Kit?
LS2?
A way to use stock?
I just want to look at all my options instead of spending over 200 on a fuel rail kit if it can be done cheaper.
Fuel Rails-
FAST Kit?
LS2?
A way to use stock?
Can the Mast Motorsports fuel rails be used on the 102? It says for fast intake manifolds but I ma not sure if its for the 90 and 92.
http://www.ws6project.com/user_stor/...oducts_id=2842
I used a stock ls3 rail, with FAST 303608 injectors (also had to use different o-rings...sorry can't remember the part number)....and made some spacers to hold the rail feet up off of the intake by 1/4" (IIRC).
The hardest part, is making the coil covers fit again.
