HELP!!!! 700r4 has me puzzled.
I have a freshly rebuilt 700r4, 1st and reverse are strong no slip but it will not shift out of 1st into 2nd. TV cable is adjusted and working correctly, I took the governor out the gear is perfect and the valve is not stuck. I dropped the valve body all the valves work fine no sticking. Took a pressure test and pressure is excellent.
I'm completely puzzled don't know what to check next. Any suggestions?
I was wondering if they gave me the wrong stall speed torque converter would that make it not shift to 2nd?
I wonder if they gave me the wrong torque converter with this tranny. It seems to me if you require say a 1400 stall converter and you install a 3000 stall converter won't that make it not shift? I don't know I'm just asking, I've run out of ideas.
Would that have anything to do with not shifting out of 1st?
Yes, when I did the pressure test pressure increased when the TV was opened.
Moderator
No it would just basically block the accumulator piston. The 3-4 accumulator has nothing to do with the 1-2 shift. I would be looking at the check ball locations or an issue with a stuck valve in the valve body. Vince
I just don't understand it, there is nothing wrong with this transmission yet it won't shift to 2nd. I'm sick of working on it, thanks for all the help guys.
Here is an update just in case someone else has the same problem.
Turns out the band was off it's anchor stud that's why it wouldn't shift to 2nd. How it came off it's anchor I don't know but that was the problem.
700r4 help
Hi I am having the exact same problem tried and did everything you did. Can you explain more on the band. Is that the 2-4 band on the passenger side of the trans. Also I just had mine rebuilt. would that be part be change when they rebuild it.
I'm sorry to say if you are having the same problem I had and you just had the tranny rebuilt then there is a very good chance the band is off its anchor stud.
Unfortunately the only way to fix it is to remove the tranny and pull the pump assembly from the front of the tranny and reset the band.
Mine was a fresh rebuild, during installation of the pump the band slipped off the stud and we never noticed it. One simple mistake caused a ton of work.
