Reverse problems
Old 04-12-2011, 05:11 PM
IHaveAHairyCat's Avatar
Default Reverse problems
Hey I need help diagnosing my firehawk. Its a 2000 firehawk and I'm having trouble making it stay in reverse.it keeps popping out and will sometimes make a grinding noise as it slipped out until I take the shifter away from the gear. Also it has been grinding going into third if I shift hard but goes in fine if I shift real easy. Please help I'm hoping I don't need a transmission
Old 04-12-2011, 05:27 PM
Also makes a sort of bangnoise when it kicks me our of reverse
Old 04-13-2011, 06:11 AM
85MikeTPI's Avatar
Blocker rings, shift fork pads, synchro keys. All the stock parts that wear and break and that get upgraded during a rebuild. You don't need a new transmission, just a rebuild.
Old 06-01-2011, 11:08 AM
A rebuild of the whole tranny? or is it just replacing those parts you just mentioned? I'm not very savvy on big maint. like this. also do you have any idea how much it would cost? and is it something I can do or should I bring to a shop. Thanks for your input!
Old 06-01-2011, 07:16 PM
JrodCamaro's Avatar
I have the same problem with reverse, most likely wear pads on the fork. Not alot of fun to change from what I've heard. Was racing today and make a quick grind noise going into 3rd and lost ALOT of power, I'm a really quick shifter and sometimes release the clutch before it's all the way in gear. Was fine after thou and had full power, not sure what happened. Haven't gotten the fork pads priced yet. Check out this thread a guy explained to me how to change it
https://ls1tech.com/forums/manual-tr...e-problem.html
Old 06-02-2011, 08:59 AM
z_speedfreak's Avatar
when I shipped mine off to get rebuilt(mainly for a bad rev synchro) they opened it up and told me what was fine and what needed replacing, then I choose what to upgrade
Old 06-02-2011, 02:21 PM
brians91formula's Avatar
Ryan,
check out http://www.texasdrivetrainperformance.com/t56.html for a cheap rebuild.
Ryan,
Old 06-02-2011, 08:52 PM
JHash's Avatar
Mine does the same thing. Guess I need a rebuild too, any good transmission shops in the Denver Metro area?
Quick Reply: Reverse problems
