pilot bearing
Old 04-12-2011, 05:14 PM
SilverSS07's Avatar
Default pilot bearing
Hey guys have a 95 TA and am in the middle of putting in new clutch/pp, etc. I bought the clutch kit from Autozone and it came with 2 pilot bearings. One is more of a bushing and is tapered on one end. The other one has needle bearings in it. They are identical diameter, size, etc. Which one would be better to use? I've been searching and haven't found anything. Thanks!
Old 04-12-2011, 08:16 PM
SilverSS07's Avatar
Ok well I finally found the debate thread on here when I googled pilot bearing or bushing and decided to go with the bearing. Now my question is which way does the bearing go? I would assume where the numbers are stamped on it is the back. The bearing sits in it with maybe 1/8' extra on one end. I was assuming where the bearing was flush with it was the front. Can anyone verify this? If I'm right then the pilot bearing that was in there was installed backwards lol
Old 04-13-2011, 03:47 AM
jmd
jmd's Avatar
It works either way. Put the tapered end to the rear of the car.
More importantly, make sure the pilot end of the input is fully into the bearing. (don't drive the bearing in the crank more than necessary.)
Old 04-13-2011, 10:58 AM
BALLSS's Avatar
this is what it should look like. tapered end towards tranny. flush with end of crank
Old 04-13-2011, 11:28 AM
01ssreda4's Avatar
Agreed with above picture.
Old 04-13-2011, 01:28 PM
wrd1972's Avatar
When I drove a recent bushing in flush, only 2/3 of the tranny input shaft contacted the ID of the bushing. Not good.
When I left the bushing sticking out ~1/4" or so, the input shaft made 100% contact with the ID of the bushing.
Old 04-13-2011, 01:30 PM
SilverSS07's Avatar
10-4. Thanks for the replies guys. Now hopefully finish up the job today
Quick Reply: pilot bearing
