What cam would put down numbers like this?
Old 04-12-2011, 06:37 PM
mean_greenZ's Avatar
Default What cam would put down numbers like this?
Here is the thread I started giving a preliminary of all I know that is done to the car and showing an idle vid to try and find out what cam is in it.
https://ls1tech.com/forums/multimedi...ound-like.html
I just got the car dynoed today. First run is cutout closed, 2nd is open. I have no idea if headwork was done or not.
Numbers are hard to read... closed is 364.59 HP 365.10 TQ. open is 370.94 HP 367.73 TQ
Old 04-12-2011, 06:47 PM
k0261886's Avatar
Something pretty small to make peak power at 5700. Maybe 224r
Old 04-12-2011, 08:54 PM
intenseblue's Avatar
something smaller. That's probably in the 37 degree IVC range Probably in the 218 range
Old 04-12-2011, 09:36 PM
so do you guys think it's cam only or that they possibly did headwork? They are the stock 853 castings.
Old 04-12-2011, 09:40 PM
bayer-z28's Avatar
^ Maybe a small cam. Hot cam? Looks like stock heads and/or stock-ish intake. My 224/228 cam climbs to 6800 fine with no dropoff.
Old 04-13-2011, 07:41 AM
anyone else got any guesses on what it might be?
Old 04-13-2011, 09:37 AM
30th t/a's Avatar
i replied in your other thread but i agree with some of you, tr220 114 or something very similar
Old 04-13-2011, 11:29 AM
offaxis's Avatar
Peaks to early and doesnt make much power. Mystery cam = Something that needs to be changed!
Old 04-13-2011, 12:21 PM
thunderstruck507's Avatar
I would blame the shorty headers and ls1 intake for the low numbers more than the cam. The numbers aren't even that bad.
Warning ricer math ahead: Figure it likely picks up at least 10-15rwhp with a ls6 intake (and revs better) and minimum 5-10rwhp with longtubes and he is right there ~385+rwhp.
Pretty typical for a small cam ls1 on a dyno that isn't overly optimistic.
Old 04-13-2011, 01:41 PM
30th t/a's Avatar
I agree. I dont think they are that bad all, especially with a a LS1 intake and shortys
Old 04-13-2011, 02:27 PM
Yea whats so bad about my numbers?? I was impressed given it has shorties and stock intake. It's also pretty rich up top. Plus I like the fact i don't have to rev it to the moon for peak power.
Old 04-13-2011, 03:18 PM
How do you know it's rich? Did they tell you your a/f ratio too?
If you don't have a good tune the numbers are even better for what you have. Don't swap cams until you optimize intake/exhaust.
Old 04-13-2011, 03:48 PM
Johnnystock's Avatar
To peak that early, 220 or smaller I guess. And I agree too numbers arent bad considering LS1 intake and shorties.
Old 04-13-2011, 04:52 PM
yes my a/f was around 11.4. I have no intentions of changing this cam out. The car is my daily driver and I was pretty pleased with the numbers. It drives like a stock car.
Old 04-14-2011, 08:48 AM
Then yes your numbers are very good for whats done.
ls6 or better intake, cheap longtubes, and a tune should put you within the range of 400hp and the car will drive like stock...good setup to me
Old 04-14-2011, 10:30 AM
kinglt-1's Avatar
agreed!
Old 04-15-2011, 12:35 AM
lusting4ls1's Avatar
^^^^im with the last two guys. i would like to know what it is now, to have mild manners and good power.lol
Old 04-15-2011, 09:46 AM
Well after hours of digging I actually found the 1st owner on here. The heads have been ported and the cam is a comp custom grind 218/218 .563/.563- 112LSA.
Also the running rich issue when I had it dynoed was due to me putting a stock MAF on it. I bought the car with a SLP 85mm and noticed the car would spark knock. I thought it was the big MAF causing it because I had no clue any of this was done. And I found out the guy had the car dyno tuned WITH the 85mm MAF. The crappy plug and wire change that the guy I bought it from was causing the spark knock.
The car originally dynoed 380hp 379tq. So I think by me putting the 85mm maf back on it should be back up to the numbers it originally put down.
Speed INc. dyno tuned it back then.
I thank him for creating such a quiet, mild-mannered combo that drives like stock and runs phenomenal!
