1320
04-13-2011, 12:06 AM
Its bone stock otherwise. I use a stingy mustang, but bone stock this car made 295 rwhp.
I now have the system pretty well iron out. Today we got some tuning done and it came out just as I planned. Stock convertor, stock car, stock cam everything.
It does have a 76 turbo, fmic, 50 mm waistgate, 2 nozzle water/meth kit, ceramic coated and wrapped exhaust. Its running about 8psi, and boost starts at about 1500 rpm. You have to drive it pretty easy to stay under 90 kpa. MPG looks like its up so far if your careful. It appears that were pretty much out of stock injector and I dont know yet if Ill get it to make a full pull on the dyno. I might have to just drop the rpm back alittle and short shift it. Drivability is basically perfect. You just think about boost and the tires pretty much melt.
Of course I kept the ac, and everything.......the only thing I had to really relocate (using an oem bolt hole) was one horn.......
any guesses on power? Anticapate that it might not go past 5000.....due to inj duty cycle
