manual valve body in 4l80e
Old 04-13-2011, 09:01 AM
nasty98z's Avatar
Default manual valve body in 4l80e
If u have a full manual valve body on a 4l80e do u have to hook the wiring harness up to it?
Old 04-13-2011, 12:31 PM
twinturbo496's Avatar
That depends on whose valve body your using.
The transgo-3 kit (that doesn't seem to work very well) requires a hot wire and a ground wire for the lockup converter. I believe that would be the absolute minimum as far as wiring goes, other setups use more electrical controls, requiring more wires.
Old 04-15-2011, 06:24 PM
zgp
zgp's Avatar
You can run with a non locking converter with no electronics. Also you will not have any pressure control. Most run at max pressure all the time. There are other options also for pressure control.
Quick Reply: manual valve body in 4l80e
