Tools & Fabrication - I need to replace air compressor's pressure switch with something else.
team39763
04-14-2011, 03:50 PM
I've had this Campbell Hausfeld compressor for about 3 years and I've had the pressure switch replaced twice. The little red knob always breaks off and we have no way to turn on the compressor. Can I replace the little red switch with something else like a light switch or something? Or is there a better option? I'm just tired of fighting with the switch for 5 minutes everytime I want to turn on the compressor.
This is what the part looks like. It's the red knob that keeps breaking/falling apart.
http://cgi.ebay.com/Air-Compressor-Pressure-Switch-CW209300AV-/250667755933?pt=LH_DefaultDomain_0&hash=item3a5cf6699d
team39763
04-15-2011, 01:00 PM
Actually, I should have worded things differently. I just want to make a new on/off switch. I need my compressor this weekend. Can I just take a screwdriver and jump the black wire to the white wire and hold it there 'til the compressor is at the right psi?
01ssreda4
04-16-2011, 02:17 AM
Should work, yes.
garygnu
04-16-2011, 08:22 PM
i have seen pressure switch with a lever.
team39763
04-16-2011, 09:49 PM
I just talked to a buddy, he said I would have fried myself if I would have touched that 220V wire with a screwdriver...that's enough to scare me. I decided to just let a real electrician show me how to wire it up correctly and not mess anything up. I'm gonna see if tractor supply has any of those lever types switches. Thanks ya'll.
Old Geezer
04-22-2011, 07:29 AM
The compressor should be controlled at the breaker.. not the psi switch.
Your electrician can wire in a remote contactor that will remove the hi load from the psi sw. The psi sw then becomes a low load controller, only.
Take a look at the high end compressors... They use the remote.
It's not all that much $$ to make a fool proof control.
