Wheels and Tires Just to get it home
Hello all. I have searched for about an hour and can't find what i am looking for. I am not really into the f-body cars, but have a 96 Impala. I have found a donor 97 WS6 for my 6 speed swap to the Impala. Problem is, the car doesn't have wheels so I can test drive it and get it on the trailer. I don't want to have to buy wheels to look at a car I might not buy. I have some round track buddies who have some wheels and tires I can borrow. I just need to know if they will fit and not cause any damage during a test drive and trailer home. I think it will be close, but just don't know.
15 x 8 with 4" back space (zero offset).
5 on 4-3/4" bolt pattern
Will the 15's fit over the brakes?
Will these stick out too far and damage the fenders?
Thanks,
Jonathan
Thanks,
Jonathan
Yeah I think you will have problems with a lot of 15" wheels with brake clearance and those wheels will stick out also.I think the stock 8" BS is 5 or 5.5".Where are you at? Maybe someone on here local to you would have stock wheels and tires they took off and could help you out??
The WS-6 came with 17" wheels as OE, but that's not important for what you want to do. The "normal" Firebirds and Camaros came with 16" wheels, with a 5x4.75" bolt circle, and most importantly, 6" of backspacing. Anything less than 5.5-5.75" of backspacing will have the tires into the fenders.
You might want to hit a junkyard for a set of the "space-saver" spare wheels/tires. I'm sure that you could get them cheap.
I found some 98 Z28 wheels and tires locally for a decent price (listed as 98-02 Z28 wheels). I was told that they might not fit on a 97 TA because of backspacing issues. Will these work on a 97 WS6?
Jonathan
Jonathan
