stange slutch pedal
Old 04-15-2011, 11:44 AM
i'm sofa king's Avatar
Default stange slutch pedal
ok, let me see if i can explain whats going on.
if i hold my clutch pedal down while i wait in traffic, when i take off, the pedal engages right off the floor, then gets hung up about half way. sometimes it will pop right back up after you take off, others you have to pull it up before you shift again. shifting after that is normal.
sometimes, the pedal will release normal, about half way it starts to grab and by the top its fully engaged and no problems.
i change the clutch fluid using the "Ranger" method about every weekend casue thats all it takes for it to get black and nasty again. i'm using the prestone dot 4 fluid.
is my clutch master about dead? or is it the slave? or is my clutch soo far dead that it is causing these problems? the car only has 46,000 miles and as far as i know it still has the stock clutch and hydrolics.
Old 04-17-2011, 08:44 PM
no ideas?
anything?
Quick Reply: stange slutch pedal
