did the drill mod, still sticking at high rpm
Old 04-15-2011, 03:45 PM
trans665's Avatar
Default did the drill mod, still sticking at high rpm
well yeasterday i saw the vid on the stickie about doing a drill mod, i got pumped up and said i could do that!!!
it took me six hours to do it, and bleed the system....i made a hole in the fire wall by the pedal to bleed the system....
so now that did not work, whats my next step??
Old 04-15-2011, 04:34 PM
Vexzer's Avatar
Shift a little slower, replace clutch with LS7.
Old 04-15-2011, 07:17 PM
Blwn_by_Twins's Avatar
Do you mean the pedal is still sticking to the floor? Remove the spring on the pedal.
Old 04-15-2011, 07:32 PM
DAVESS02's Avatar
The pressure plate is bad. Its losing its ability to disengage at high RPM's. I had the same problem and went with a Luk gold non adjustable pressure plate and got a puck style disk made at the local brake and clutch shop. I'm running a 403
and no slip problems whatsoever. I think I got $500 in the whole setup, including SFI cert. flywheel... that includes having the machine shop balance the assy.
Old 04-16-2011, 09:03 AM
keith102371's Avatar
changed mine out to a Diamond stage 2 complete clutch kit from TDP fixed mine, still with stock M/C and no drill mod.
Quick Reply: did the drill mod, still sticking at high rpm
