Sound Deadening Installation Question
I've seen some great threads here about sound deadening materials and installs. I have a question about installation on the sail panels:
Do you cut around the velcro that holds the interior sail panels secure? Or do you simply remove the velcro, lay down the mat, then put the velcro on top of sound deadening mat? I just want the plastic to be secure with no rattles, squeaks, or movement.
Thanks in advance to any of you who have some experience with this.
Ive installed mine behind the plastic, installed the plastic piece, stuck the velcro to the platiic then attached the sail panel to the velcro. Is this what you are asking? Mine works well.
So if you go around the velcro, will the sound deadening material (edead, dynamat, etc., not sure yet) be too thick for the velcro to stick? It just seems like every layer of sound deadening you add will make the plastic further from the velcro on the metal.
Thanks again for all the input thus far.
The only difference is the thickness. You can use them in conjunction with each other, all depends on budget and goals. The teklite is very nice. I use it mainly in doors in panels with a lot of space. Ill usually put a layer or so of edead then that over it for more noise cancellation. On flat areas i just use the edead.
