Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Help - stuck in the middle of exhaust removal!
Old 04-16-2011, 05:41 PM
FuzzyLog1c's Avatar
Default Help - stuck in the middle of exhaust removal!
Hey,
Headers wrapped / ready to go. Exhaust unbolted from the manifold (Liquid Wrench was a godsend there).
Unfortunately, I'm having a hell of a time trying to get the six rubber isolation mounts off of my exhaust. Do you guys have any advice regarding how to force these suckers free (ie, which I should start with)?
In the hopes that some of you visit the form in the next 12 hours, I'm going to hold off until tomorrow morning.
Old 04-16-2011, 05:50 PM
4doorvetteLV's Avatar
Use the liquid wrench on the rubber hangers too.
Old 04-16-2011, 07:00 PM
FuzzyLog1c's Avatar
It's not that they're stuck--it's more that I'm afraid that I'll break something if I put a ton of pressure on the mufflers. The rubber gives quite a bit, but not enough to get it over the end loops without some "help."
Still, I'll give it a shot.
Old 04-16-2011, 07:52 PM
DirtyDirk's Avatar
Liquid wrench & a small pry bar. Some of them can be a pain.
Old 04-16-2011, 10:04 PM
rjoffe's Avatar
Big pry bar
Old 04-17-2011, 09:20 AM
tityrous's Avatar
What exactly are you trying to do install headers? What exhaust are you taking off stock?
Old 04-17-2011, 05:17 PM
Strokinit383's Avatar
Just need some lube! I used a pry bar and wd-40.
Old 04-17-2011, 07:45 PM
FuzzyLog1c's Avatar
Thanks guys--you were absolutely right. Little bit of thin oil (WD-40 or Liquid Wrench) works wonders. Even getting them wet helps (it's nasty, but I bet you could spit on them if you WANTED).
Quick Reply: Help - stuck in the middle of exhaust removal!
