Help with tire size on lowered WS6
Old 04-17-2011, 05:58 AM
Joinedthedarkside's Avatar
Default Help with tire size on lowered WS6
i need help with a tire for the track/street, i have been running mickey thompsons 26X10.5X16 on stock wheels but am running out of gear and having to finish in 5th gear at the traps.
so i wanna run a little bigger tire but i know my choices are limited, problems are, 16X8 wheel and running eibach pro's
so i see some guys running 28" tires but everyone i have seen running them is stock height, i found some 28X11.5X16 that are 27.69" tall but not sure if that will fit with my springs
any advise/previous experience would be much appreciated
i am willing to run anything from 27"-28" if they will fit without issue
Old 04-18-2011, 10:25 PM
808z28camaro's Avatar
5th gear?!? what gears are you running? t-56 6 speed? I only hit 3rd gear almost going to 4th with 3.90 gears. when i was running my stock gearing (3.42) i only hit 3rd just before the traps.
Old 04-18-2011, 11:44 PM
1BAD02WS6's Avatar
thats kinda odd. stock i would hit 4th well before the traps and even with a cam (6.5k redline) and still stock 3.42s. Now with the 4.30s and a 26 inch tire im at 7k in 4th at the traps
Old 04-18-2011, 11:57 PM
Crap. Im sorry...i meant hit almost 4th through traps stock and solid 4th almost 5th with 3.90s. using street tires spinning off the line with a 2.22 60 ft. had i been using drag radials it might have effected the outcome. Also my ram clutch is on its last leg slipping a little. Switching to monster stg 3 soon. I know i should be hitting 1.7s 60 ft.
Old 04-19-2011, 02:42 AM
i am running 4.10's and a 26" tire but 127mph is not putting me in the right gear with that tire height
Old 04-21-2011, 07:02 AM
anyone?
has anyone ran a 28" tire on a lowered trans am or camaro?
Old 04-21-2011, 04:50 PM
Ws6DieseL's Avatar
[attach]Help with tire size on lowered WS6-photo0188.jpg[/attach] On the street /street racing I'm good. But when I launch it hits. Just ordered some drag bags hoping that does the trick
Old 04-24-2011, 08:04 PM
what size are those M H tires?
Old 04-25-2011, 06:00 PM
Ws6DieseL's Avatar
Old 04-25-2011, 11:27 PM
thanks diesel, with the measurements of those tires, the Mickey Thompson 28x11.5x16 should definitely fit, they are a hair narrower than yours and only 27.69" compared to your 28" so slightly smaller all around, should be nice on there
Old 04-26-2011, 06:34 AM
Mongoose WS6's Avatar
my friends had eibach sportlines and i beleive he was running 295 50 15s
it was a tall tire and he had lil rubbing issues
Old 04-26-2011, 09:05 AM
15" wheel, means it wasnt the stock wheels with proper backspacing, so maybe it was his wheels, cause a 295/50/15 is only a 26.8" tire and that should clear easily so it had to have been his wheels
Old 05-02-2011, 06:53 AM
anyone else?
Quick Reply: Help with tire size on lowered WS6
