Road Racing - Getting ready for auto -x have Q'S
Indyjc
04-17-2011, 09:49 AM
I have added a ps cooler, tranny cooler and have read some where some guys are replacing the oil pan drain bolt plastic washer with a brass or metal one. Seems the plastic ones tend to want to melt? Any body replace or have any problem with the plastic washer? Thanks
SVThuh
04-17-2011, 02:47 PM
I doubt you will have any issues with the plastic washer melting during Auto-X..
I have been running HPDE's where I have been running my car at high RPM's for 20-60 minutes at a time and have never had an issue. I however did ditch the stock PS cooler and switch to a 2 row Derale cooler mounted where it receives good air-flow. Pump has survived thus far.
ZexGX
04-26-2011, 07:22 PM
If it melts, you have bigger problems than a plastic washer. The type of problems that require an oil cooler.
I was looking into this yesterday. Do you have pictures of your setup? Perhaps a new thread to post the pics in? My car is 40% street, 40% aggressive cornering, and 20% drag strip, but I still don't want the stock cooler failing on me and dumping PS fluid into my coolant.
SVThuh
04-26-2011, 10:41 PM
I will try to get some photos up tomorrow for you.. I should be swinging by my shop and Ill get some shots.
FASTFATBOY
04-27-2011, 06:09 AM
Go to Frrax.com search it.
ZexGX
04-27-2011, 11:48 AM
Thanks!
Not helpful... What I found was your post that said that Perma Cool is no longer around and that you used a Derale. No other topics centered around power steering cooler locations... Search terms used: derale cooler
I suppose I can dig around in the other cooler topics, though.
SVThuh
04-27-2011, 05:11 PM
Here it is... Not the cleanest install job I have ever done, but it had done its job quite well over the past year and a half or so.
http://farm6.static.flickr.com/5184/5662142727_c9899f8918_b.jpg
http://farm6.static.flickr.com/5225/5662140825_039e486513_b.jpg
http://farm6.static.flickr.com/5062/5662140769_7769b9a3d1_b.jpg
FASTFATBOY
04-28-2011, 08:07 AM
Look.in here and search again....
http://www.frrax.com/rrforum/index.php?showtopic=14879&hl=power+steering+cooler
I put the Derale in lower right of my rad shroud, cut a hole and mounted it .
FASTFATBOY
04-28-2011, 08:34 AM
Found it
http://www.jonaadland.com/PSCooler.html
