Fuel Pump Pin # on PCM
I keep reading that the fuel pump is Pin #9 (Dark greeen/white wire)on the red PCM connector, but have yet to find a solid write-up with pics. Whats the easiest way to locate this wire? Without unbolting the connector, I tried simply counting over 9 wires from the left and did end up on a Dark green/white wire. Coincidence or is this in fact the correct wire? Or am i looking in completely the wrong location? Reason I ask is I'm trying to put a kill switch in, but am not too familiar w/ the pcm
