need some info, trans not shifting into 2nd
Old 04-17-2011, 11:17 PM
IamSam's Avatar
Default need some info, trans not shifting into 2nd
My 02 Z28 will not shift into 2nd gear unless I let of the throttle, then it will shift fine. It shifts fine into all other gears and reverse with no issues. No funny noises from transmission either. The fluid is brown color so there Im sure the trans is... toast. But someone told me the TPS can cause this issue as well? I get a random TPS low voltage code every once in a while.
